Nope. And finding a good motor a bargain pick-n-pull isn't going to happen.
Subaru parts are a commodity out here. Look at this map...I would suggest the OP start looking on the usual engine sourcing sites and local salvage yards to Denver.
Nope. And finding a good motor a bargain pick-n-pull isn't going to happen.@traildogck do you know of nice big cheap pick and pull parts yards north of where you are? in case he's looking for heads. ..or even a long block
(he's close to WY).
in US / Canadian spec years for the EJ25 N/A of 2000-2004:By the way - I keep seeing these engine codes being bandied about; EJ250, EJ251, etc.. How do I know what I'm working with? And is there a guide online that explains the differences?
Oh, someone mentioned mileage earlier - the car is around 198,000 mi..
I have used cheap tire and wheel cleaner to remove crud from red lock-tite,I'll add that I haven't tried oven cleaner, because I hear that it eats aluminum, and I haven't tried methylene chloride based paint stripper.
thanks eagleeye - after reading the link, I decided to go ahead and remove the valves and replace the stem seals. I took the heads to the car wash and gave them a good dousing. I notice that there are hex plugs at both the front and back of the head, as well as two inside the head - are all four of these plugging the oil galley? And if so, would it be a good idea to remove them to facilitate cleaning?kitesurfer took some nice pics here and made a long description.
http://www.subaruoutback.org/forums...s-jdm-ej251-diy-head-gaskets.html#post2007610
https://www.amazon.com/gp/product/B00BGGBQ6Y/ref=oh_aui_search_detailpage?ie=UTF8&psc=1quick question. so what year turbo engine gasket fits 2001 2.5 sohc NA engine ? is it from 2009
will order those . thanks a lot. i wonder what other parts i could change since i will go into that road.https://www.amazon.com/gp/product/B00BGGBQ6Y/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Genuine Subaru 11044AA642 GASKET CYLINDER
This is the one you need and the one that has been on my 02 since I replaced the shortblock.
Arron,
When I did this on the 2001 with the intake manifold left on (but lifted slightly), I removed and replaced the heads from under the car, so the intake manifold was not an issue. We had rubber bands stretched between each adjacent bolt (horizontally) to keep the bolts from sliding while manuevering the head in-place. The bands were right under the top of the bolt and allowed us to move them a bit, but they would not slide around or slide out of the head as we moved the head into position.
For your torque wrench: Use a 3/8" click type torque wrench. Get a 3/8" to 1/2" socket adapter, and use a 1/2" socket. I found that combination gets the wrench out far enough from the rockers but gives you clearance inside the body side rails. It should work perfect. After you complete all the steps but the final 2, get a sharpie and draw a vertical line on each head bolt. Then complete the 80 to 90 degree turn. Rub off the mark and remark a new vertical stripe. Then do your final 80 to 90 degree turn. For the last 2 steps, just use a breaker bar. If you have cleaned the mating surfaces well and have the head surfaced (my shop just polished them up to a mirror finish), you should have no problems with your HG from here on out.
