356 CCA is obviously adequate for the FB25 engine, as long as the battery is healthy, fully charged, and actually capable of delivering that level of starting current.356 CCA is a joke in my opinion.
You are describing a Brand NEW Battery. Not OEM that has been used for 3 years in my case.356 CCA is obviously adequate for the FB25 engine, as long as the battery is healthy, fully charged, and actually capable of delivering that level of starting current.
You are correct. 356 CCA 's leaves no margin of error for degradation.Yep, clearly gets the job done, just leaves little room for degradation.
In that case your complaint is not with a 356 CCA battery, but rather with a worn out, 3 year old battery that may (or may not) have been marginal even when new.You are describing a Brand NEW Battery. Not OEM that has been used for 3 years in my case.
In my opinion 356 CCA 's for any 4 cylinder car engine sucks. My engine starter really performed very poorly in cold weather from Day 1 . Battery did fine in warm weather. My complaint is with 356 CCA's.In that case your complaint is not with a 356 CCA battery, but rather with a worn out, 3 year old battery that may (or may not) have been marginal even when new.
FWIW, I preemptively replaced the OE batteries in both our Legacy and Outback at approximately 3 years, even though neither had ever given us problems. My anecdote is just as valid as yours.
If you're happy, I'm happy.My New battery with 550 CCA's has made a huge improvement in cold weather starts.[From Day 1]
fixed that for you. 😁356 CCA isobviouslybarely adequate for the FB25 engine, as long as the battery is healthy, fully charged, and actually capable of delivering that level of starting current.
TI have a 2018 3.6 OB it that is 3 years old. I still have the OEM battery and have had no problems. However, with all the posts about the bad Subie batteries, I decided to test it with a volt meter. Here are the readings.
1) First thing in morning, car has not been driven in 24 hours, 50 degrees 12.24 volts was the reading
2) After driving car for 1 hour, car not running 12.5 was the reading.
3) While car was running 14.35
Any thoughts....time for a new battery? If I get a new battery I was thinking of getting an Interstate from Costco, do they carry a group 25 battery? If not, should I get a group 24? will the heat wrap that is currently on the OEM battery fit a group 24? I will put in new battery myself. Thank You
Thank you everyone for the advice. So I ended up getting a group 25 from Costco for $79. Put it in very easy and car works great. Had to reset the windows and the tire pressure gauge. The costco group 25 is a Interstate Battery with 550 CCA. Better than original. We will see how it lasts. Thanksfixed that for you. 😁
Any idea what car uses the Group 24? I couldnt find anything.So just tell them it is for a car that uses the battery that you want to buy. I doubt if they follow you home and check what you install it in.
I believe that Honda V-6 products all use group 24 batteries. Odyssey, Pilot, Ridgeline.Any idea what car uses the Group 24? I couldnt find anything.
Odyssey Says it’s 24F, same as Sienna.I believe that Honda V-6 products all use group 24 batteries. Odyssey, Pilot, Ridgeline.
All of our Odysseys ate batteries every 2-3 years.I believe that Honda V-6 products all use group 24 batteries. Odyssey, Pilot, Ridgeline.
Repeating what you probably already know, avoid Group 24F, which is a reversed-polarity variant of Group 24. (24F is used in many recent Ford vehicles.) Getting the battery polarity backwards can ruin your day ... a very costly mistake.Odyssey Says it’s 24F, same as Sienna.
Right. Good to remember. Too bad because it would work for either of my vehicles then.Repeating what you probably already know, avoid Group 24F, which is a reversed-polarity variant of Group 24. (24F is used in many recent Ford vehicles.) Getting the battery polarity backwards can be a very costly mistake.
similar, replaced last November the 48-month old battery that tested ok but had discharged and been revived once/reconditioned ... Based on experience I didn’t trust it to get through this winter, especially with mainly short trips due to Covid etc.In that case your complaint is not with a 356 CCA battery, but rather with a worn out, 3 year old battery that may (or may not) have been marginal even when new.
