With the key fob in hand when I touch the passenger side door handle all locks are suppose to unlock at once. Instead they unlock one at a time. In other words five different beeps. I just had this door replaced at the dealer due to being run into. Is this a computer problem that can be corrected. The drivers side unlock works as it is suppose to.
2013 3.6R Limited
Perhaps the door lock actuators / door modules need to be recalibrated. Since your dealership performed your replacement door install, they still owe you the recalibration procedure (assuming there is one). Have you talked with them about this issue?
2010 Subaru Outback 2.5i Limited
Depends. Was the problem around before you had the door replaced? If not, the dealership likely fudged something up in the replacement process. If the problem was around before the replacement, you could be looking at something far more complicated.
