Hmm? Thinking release bearing but pretty sure with car in neutral and release bearing failing you'll actually get the car to creep given the bearing cause enough friction you get some transfer of power to the gear box still.
01 - could be some type of issue with brake pins hanging up and holding brake pad pressure on the discs. Whats the story on the gear box oil change and diff gear oil?
Have you checked the wheel bearings?
