1 - 2 of 2 Posts
2011 Outback 2.5L CVT
So over the weekend I installed a subaru oem remote start into my 2011 outback. Now the driver's side power window that used to roll down all the way after holding the switch for a short period no longer works. Is there an option that turns this feature on and off that I have forgotten about?
Discussion Starter · #2 ·
Just posting the answer since I found it in the owners manual page 2-23.
If the vehicle’s battery is disconnected due
to situations such as battery or fuse
replacement, the following functions are
deactivated.
. One-touch auto up/down function
. Anti-entrapment function
Initialize the power window in the following
procedure to reactivate such functions.
1. Close the driver’s door.
2. Turn the ignition switch to the “ON”
position.
3. Open the driver’s side window halfway
by pushing down the power window
switch.
4. Pull up the power window switch and
close the window completely. Continue
pulling up the switch for approximately 1
second after the window is closed completely.
1 - 2 of 2 Posts
