My engine was throwing a p0171 code. Mechanic told me both a/f sensors are bad. He cleared the code too. So new a/f sensors in it and mileage seems to be fixed (since it was too lean the car ATE gas) but the car idles really rough and wants to stall when I come to a stop. I've only driven the car about two miles with the new sensors, so how long can I expect this low idle to last?
2018 2.5i Limited w/EyeSight
Can't speak exactly to the outback in this particular case, but I've the same thing done to other cars and it usually took a day or so to get back to acceptable and then quite a while to return all the way back to normal - usually a couple of weeks.
2001 VDC Wagon - White pearl - 302,000 km
He may have pulled the battery or the ECM fuse, which returns the ECM to factory settings. The ECM needs time to "learn" how to run. Your near-stalling situation is most likely the ECM testing how low the idle control settings can go, before it stalls.
Should be back to normal after 3 or 4 full closed loop drive cycles.
is the check engine light off? Then it's probably relearning the idle.
depending on the engine, there can be a hose from the IACV that gets knocked loose under the intake tubing when work is done.
