1 - 20 of 45 Posts
Hey guys!
I'd like to add an "easy" 20hp on my 2011 outback 2.5 with cvt. Any of you have an idea of what I could do, what parts and where I can get them? I don't wanna change the exhaust but I was more thinking of an ecu mod...
Thanks!
Fresh Out of Outbacks!
Find a tuner who will take it on... Lots of people out there tune Subaru ECUs though its rare to find one who will work on a non-turbo car.
After that its easy- pay the money, sign the waiver and off you go.
If you have a lot of time and some computer skills there is open source software to DIY. I wouldn't suggest it if you haven't tuned a car before though.
2015 Subaru Outback 2.5 Limited Eyesight Lapis Blue Pearl
I'd be curious as to how the CVT would hold up to that. For the 250hp turbo Subaru created a high torque CVT...
remove approx. 200 lbs from the car.
05 OBXT 5eat stg1.2
Hey guys!
Thanks!
Easy 20hp and 2.5i is a contradiction. It won't be easy or cheap.
Meh.
I has wagons.
Hey guys!
Thanks!
Nope. Just nope.
Spinnaker and tail wind?
good luck. if u want more power from that engine, try a raptor supercharger kit, let us know how long the CVT lasts Raptor Superchargers
This might well be the most realistic suggestion so far. Replacing the spare tire, jack, lug wrench etc with a AAA card is a great start. That's got to be 40lbs or so right there. If you stripped out all the trim and upholstery from the cargo area, you might get another 15-20. Lose the back seats altogether and keep the fuel tank down to half and you might hit those numbers.
The aftermarket has focused its attention on the turbo version of this engine, so there isn't much out there in packaged form.
Watch out for the generic crap- there are shady sites selling "chips" for Subarus. Subarus don't use chips. They have their own chips. You can re-write the fueling tables embedded in the Subaru's chip. The as-seen-on-tv chip is usually just a resistor to fake out the intake air temperature and make it appear to be a few degrees colder. This can give a slight performance boost, but it's bad because the engine management will eventually have a problem with this false data.
Banned
2007 Outback XT Ltd
Since when has the turbo engine been hooked up to a CVT? Never in an Outback XT (manual and slushbox trannies), and never in a WRX (manual only)..... what is left? Did the Legacy GT 2.5 turbo have a CVT option?
John Davies
Spokane WA USA
If he could get lighter wheels, reduced rotational mass is an even greater boost.
although it depends on the mass of the car as a percentage (I think) most normal sized cars will respond to the reduction of 9-13 lbs or so the same as if 1 hp were added. There are on-line hp calculators where you can plug in some numbers and play around with reducing the weight to see the performance increase.
2013 Outback 2.5 Premium
When I'm not going on a hiway trip, I'll only fill my tank up about half way. Why carry around aprx. 70 lbs. more than I need?
Was wondering how much horsepower gain can be had to reprogram the engine to run on premium gas only?
'14 3.6R Outback
John Davies
Spokane WA USA
2014 Subaru Forester includes direct-injection turbo
No, it's not actually for sale yet.
Then there is 2013 Subaru Legacy Gets 296 HP Turbocharged 4-Cylinder | AutoGuide.com News
which is not avalible in america.
WRX rumor...
http://blog.caranddriver.com/turbo-...ebuts-in-japanese-legacy-will-power-next-wrx/
But then, you were not specific then were you. ;-)
'14 3.6R Outback
Actually the computer can make those adjustments for premium automatically. I'm doing an informal test right now...
The easiest way to upgrade is Trade up to an older OBXT
DIY-Turbo 2.2l OBS 12.89s 1/4mile @ 106.17MPH
K&N Drop in air filter
LW Crank pulley
Redline 75/90 in the diffs (? if the CVT's have gear oil in the front diff like the 4eats do)
Synthetic oil in the engine (which should be there anyany)
The above should net a few hp cheaply.
You can net a few more HP with LW wheels/tires but it will not be cheap.
EL header / exhaust nets about 15whp on older ej25 n/a's (1996-2003/2004) with the old "Y" pipe, but you should already have OEM catted el-headers on your car.
Here is a link with dyno runs for nay-sayers:
http://www.rs25.com/forums/f5/t48917-obx-vs-mrt-header-dyno-results.html
If you have a smart phone, you can download some apps and do your own before/after runs as you add mods. Torque is a popular app that might work for some folks.
Premium fuel will usually not help a car designed for regular. If you increase compression with skinned heads, a turbo or s'charger or maybe different rod or piston, then higher octane and a tune/altered ignition timing, begins to be a requirement.
1 - 20 of 45 Posts
