Ecu readings help!!!!
672 4
hey guys hope you can help me.
I just did a head gasket job on my 02 OBW. I was having problems that my RPM would randomly drop and the car was running rough. the CEL turned on and it came up with code P0122 throttle position sensor low input.
I adjusted the TPS and i ran a lot better the check engine light didn't come back on, but i was still having some issues with hard shifting and dropping RPM.
is the ECU resetting its self that is why this is happening?
I also attached a few pictures to this post that ive been reading the ECU and at random point the ECU is reading that everything is dropping Engine coolant and load. Is the ECU going bad?
· On the Super Mod Squad
