EJ25 now FB25
26333 25
With the 2013 model year Subaru began using a different engine in its Outback than in previous models. Among the changes to the engine was a small bump in horsepower and torque. It may be too early to ask but, does anyone that may have had a chance to evaluate both Outback engines notice a difference in performance?
1 - 20 of 26 Posts
A change in font size might be in order.
The FB/FJ difference is not so much a performance difference but a maintenance difference.
The FB timing chain is better than a FJ timing belt. Head gasket design is improved too. The FB also gets a bit better mpg .
...does anyone that may have had a chance to evaluate both
Uhh, a 1.7% horsepower difference should have the same
performance effect as a 60 lb weight difference. That's 8-9
gallons of gasoline....
...or cleaning (some of) the junk out of the back seat,
Looby
2013 Limited w/EyeSight
No need to shout!
I have 2013 with FB, mother in law the EJ in a year old Limited much the same except EyeSight. For the most part I have to look under the hood to really tell a difference.
Handling is a much bigger difference.
I wanted to know if a low and mid range torque improvement was noticeable.
Peak power and torque increased by 1.8% and 2.3%, respectively,
while displacement increased by 1.7% (2.457 versus 2.498 liters).
So, 'improvement' in specific output (hp per liter) is less than 0.1%.
The new engine's torque peak actually moved 100 rpm higher, so
it seems extremely unlikely that the new torque curve has been
moved toward the low and mid rpm range.
All new!!! ...but essentially unchanged,
Looby
...a 60 lb weight difference...
You keep over 60 lbs of junk in your back seat? Is this a new form of hoarding? :D
Forget HP numbers and curves, I wonder if the responsiveness of the engine has changed. Not that mine is horribly unresponsive, but the way an engine responds to throttle input is about as important on the street as anything.
Don't take the dogs to the drag races. ...or the Outback.
More than anything else, throttle response depends on
gear selection.
...in a hurry? DOWNSHIFT!
Looby
Discussion Starter · #13 ·
Looby
Which engine (the short or long stroke) would you say would have the better performance numbers?
Fresh Out of Outbacks!
From Looby's post, it's right there- the FB is about 2% better in the numbers department.
That's a really tiny difference. I would not use it as criteria to choose between the two, as there are plenty of other factors to choose from.
The one with less fuel in the tank or fewer dogs in the wayback.
...performance = power/weight = languid/portly,
Looby
The real news with the FB engine is the reduced maintenance costs. I just did a bit of back-of-envelope math.
Depending on your definition of a "timing belt job," the FB will be between 0.5 and 1 cent per mile cheaper to operate as it uses a permanent chain instead.
If the FB has no head gasket issues over its life, that's another cent, maybe cent and a half cheaper.
Also a base-model 2013 (with FB engine) is about 40lbs lighter than a 2012 (EJ)
2013 Outback 2.5 Premium 6mt
I was surprised the EJ to FB change didn't include DI. I wonder if the current head geometry can't incorporate DI?
My opinion is that it will be a selling point for future models. Subaru gets a double bonus by waiting for DI. They get to see how the FB25's quality is for a couple more years plus they will be able to use DI as a sales tactic.
1 - 20 of 26 Posts
