I'm about to remove the oil pump on my '03 2.5 so that the crank seal can be replaced - may as well do that while I'm replacing the timing belt stuff.
Is there any way, short of dismantling the pump itself, to identify which width oil pump it has? If it has the 7mm, I want to replace it with the 9mm version.
Also, any special trick to removing the timing belt sprocket off of the front of the crank? This one seems to be on rather solidly - with trying to pry behind the timing ring so far, it doesn't want to move, and I do not want to screw up that ring.
