Obviously never attempted an engine swap before... just FYI...
I've seen a bunch of people not reccomend putting an EZ30 in an EJ25 model Subaru but why... is it really that much of a headache?Most people want to take the dash out or replace the entire cars wiring loom etc etc, though there's people that haven't done that yet the speedo works fine, just has a 1.5x speed applied to the tacho due to 6 cylinder vs 4 cylinder.
So just to be clear I do have everything I need for this swap as far as I know. I have the ECU, TCM (located on sterring column), key/fob from the EZ30 and the reader on the ignition barrel, 5AT, rear diff, driveshafts and tail shaft.
I am trying to do this as easy as possible without requiring the need to replace the cluster or the key my Outback currently uses, though not an issue I just don't want to have to go through the trouble of matching my original cluster KM's with the replacement cluster just yet. Though I know it's possible to completely remove the immobiliser requirement altogether, that will remove the need for the key fob and the ignititon barrel sensor to match with everything else.
My concern with this swap are fuel lines and location, engine bay wiring (cooling fans etc etc), Brake booster. If I have the rear diff, tail shaft and transmission from an EZ30 equip model (Liberty 2005) which should be a direct bolt in... I'm looking for help in regards to all of the above plus the 5AT and fuse box wiring. Even if my 2.5L EJ253 wiring loom magically has the same pinout as the EZ30 for the transmission... would I still need to match the pinout from the cluster? Surely it's not completely different between both cars.
For reference EZ30 from a 2005 Liberty and my car is a 2007 Outback...
Just looking for some guidance, thanks.
