1 - 7 of 7 Posts
2004 Outback Wagon EJ259 - 4EAT
My 04 OBW has an EJ259. There's a little weepage on the underside of the heads, but nothing to be overly concerned about. Any oil loss is undetectable and the coolant looks/smells good. I'm just doing a little research to keep myself informed.
For other SOHC EJ25s, the 11044AA610 head gaskets seem to be the best bet, but I haven't seen them mentioned with the EJ259...are they compatible with my engine?
The 610 gasket is for 1996-1998 (and 99 OBW Leg) EJ25's - DOHC's. It is not for SOHC EJ25's.
00+ EJ25's I'd use the EJ25 turbo headgaskets.
DIY-Turbo 2.2l OBS 12.89s 1/4mile @ 106.17MPH
+1.
Avoid the single layer metal HGs with the black coating, get 04 STi MLS HGs - they are the same price as the leak-prone HGs.
Subaru used MLS HGs on ej222's stock & these engines never had HG problems (even when you've run DIY boost for 8+years / 60k+ miles like I have.
Oh, whoops, looks like I should have proof-read my post to make sure I pasted the right part number in. The gaskets I had in mind were the 11044AA642 ones.
I apologize in advance if I seem rather dense on the issue.
Heh, I shouldn't have jinxed it. Found two drops of oil in the driveway today that weren't there previously.
Looks like i'll be doing this sooner than I thought.
right on, the answer remains the same - use the EJ25 Turbo headgasket, not that 642 gasket you mentioned.
1 - 7 of 7 Posts
