I'm having some issues with the DS door recently. Drove to work a couple weeks ago with the front windows down, then shut them when I got there. When I left, none of the window buttons would work on any of the doors and the lock button on the DS door wouldn't work. The PS lock would lock/unlock the doors and the fob did lock/unlock the car though. It continued not working for several days, then suddenly worked again, although the auto up feature didn't work until I reset it. Now a couple weeks later it has happened again. This time as I was stopping at a store with all the windows down. Same problems with all the buttons. The DS window button would make a faint noise the first couple times I pushed it then nothing. In/out of gear didn't do anything. Turned the car off then power back on nothing. Then I opened and slammed the door and it suddenly worked again and I was able to roll up all the windows and use the lock button. The auto up feature isn't working again so I'll have to reset that again.
Also during this time I realized the front DS door speaker isn't working. The DS dash speaker still works but when I answered a Bluetooth phone call I could hardly hear it even with the volume turned up. I also verified this but adjusting the stereo so all sound was through the DS front speaker. After I bought the car, I remember hearing a loud beep/noise from the front speakers when trying to setup my phone Bluetooth. But didn't notice anything else at the time. The DS puddle light also wasn't working and I found it was unplugged and not just loosely plugged in but the wire was actually back inside the door. I've also had to tighten the DS mirror. It was making noise and after removing the triangle cover inside, I found 2 of the 3 screws were loose. So I'm not sure if the door had been damaged or apart before or what.
Not sure any if any of this is related or not but it sucks to not be confident you will be able to get the windows back up when you're going someplace. The car only has 40k miles so shouldn't be having issues already. I'm sure I'll need to take the door apart to look for anything obvious, but I was hoping someone would have some ideas on what to check.
Thanks.
Thanks.
