1 - 9 of 9 Posts
I have a 2008 Subaru Outback. The battery went dead and the car wouldn’t move. Supposing the electronic E brake locked. Battery died from non-use. Battery now charged to 12.6v and still the car won’t move. What next?
2008 Subaru Outback XT (MT) & 2016 Subaru Outback Ltd
I have 2008 manual and there is no electronic e brake on those cars. Might be a different story with an automatic transmission. Let’s see what others say. Is it possible brakes just seized up from non-use? Had it happen on my Hyundai years ago. Good luck.
2005 Outback VDC limited 3.0r
Do you mean it won't start? Cranks but won't stay running? Literally won't move? Won't shift out of park if auto? If literally not moving, while in gear. Then points to brakes seized up. Sometimes getting under the back and tapping with a hammer frees up.
I don’t have the manual handy, but I remember it covering unlocking the brake if things go wrong.
I have a ’12 Premium 4-cylinder with CVT. If the brake is engaged and I don’t release it, when I hit the gas in reverse or drive it automatically releases on its own.
2012 STI, 2007 Impreza RS
2008 does not have electric e-brake.
Only a manual lever in the center of the front seats
It won't move while in neutral.
okay. I made the supposition not know all the facts, assuming a locked electronic brake can be caused by a drained battery. No electronic e-brake the car not moving as in not even rolling means there must be another reason.
Likely your parking brake shoes are stuck. Try driving it forward and backward a bit while moving the parking brake lever up and down. If that doesn't work, you can try tapping the back brakes with a small hammer. Worst case, you will need to pull the back brakes apart and possibly replace the parking shoes.
How long has it been sitting?
I have lots of parts cars, and after sitting over the winter many times a wheel will seize up.
I never put the e-brakes on if the car will be sitting a long time.
1 - 9 of 9 Posts
