Subaru Outback 2019. I want to affix an emergency light bar on my rear window, and it uses suctions cups. Will the cups damage the lines for the rear window defrost? I'm going to try to stick them in blank areas but the diameter of the cups are greater than the line spacing for the defrost. Any feedback is helpful thanks, -d
2018 3.6r Touring, Black, modifications: 255-55-zr18 Continental DWS06
Have you added aftermarket tint to the glass? It definitely won't damage defroster ceramic then. (In fact, your defroster will most likely perform even better with the tint)
I did a Google search for your question out of curiosity. Several comments about the defroster not causing damage to the suction cups bit no mention of cups damaging defroster ceramic.
Sent from my Pixel 2 XL using Tapatalk
Hi thank you for the reply. I read it when you sent it but never replied back. No tint. I am only concerned if the suction cups will damage the defroster lines.
