I have a 2007 Subaru Legacy 2.5. It runs well but if I accelerate harder than normal the check engine light/cruise light comes on. I find a 303 and 304 error code. Car has new plugs wires and coil plus a new timing belt. Idle is fine, starts perfectly and runs around town for my wife just fine. Problem is if I run the RPM up a bit higher the lights come on. If I erase them they will stay off until the next time I push it. Ideas?
how old in years and miles, are the plug wires: subaru likes NGK (or whatever the dealers have sold)
and what brands are these things you just put in:
plugs: subaru likes NGK
coil: subaru OEM only. aftermarkets suck.
(even a used subaru branded one is better.....on my 2002 original it has a "subaru" label etched into the front)
____
maybe the plug wires are loose at the coil or the plugs.
any oil on the plug 3 and 4?
alternatively could be a engine ground, although they typically make for all 4 cylinder misfires, I guess one could be close to the back of the engine.
03 H6 OBW & 06 WRX Sportwagon
did these codes appear before the work was done?
what brand of plugs/wires/coil were installed?
was there oil on the plugs and wire boots on the old parts?
undeleted. I forgot to ask such things as if this was a pre-existing condition.
so....I actually need to delete #5 ?
lol
EDIT - uh, the ORIGINAL #5 or was it #3
I give up
