21 - 25 of 25 Posts
Discussion Starter #23
in addition the the o-rings on the at-comp. hoses, older cars can have hoses that leak - from the crimps or thru the hose itself. And the Hi and lo ports can leak too.
I replaced the o-rings on the A/C compressor. The low-side one was probably fine, but the high-side one had turned into something resembling bakelite. Rather than slip off its mount, it cracked in two!
I have since charged the system (didn't evacuate it first), and the compressor will now kick on. If it holds some pressure for a couple of days, I'll assume that was it and have it vacuumed and recharged.
Discussion Starter #25
The system held charge for awhile. It would cycle off and blow warm on the freeway, so it would cool the car but not as well as I know it can.
I was able to take it back and have it vacuumed and recharged for free. It seems to blow as cold as ever!
Coming up soon: oil change and a bunch of deferred maintenance. Basically, 30k service and a brake job.
21 - 25 of 25 Posts
