Backstory:
Found a 2000 OBW, Auto, with 106k miles for the Teenage Surfer in the house.
It had a blown Headgasket.
We chose to do a full workup with Timing Belt, Waterpump, etc before being released to the said teenager..
It made sense to pull the motor and do this work out of the car.
I noticed there was not a DIY thread here for Engine removal, and people suggested I did one over on my original thread here:
http://www.subaruoutback.org/forums...644-bought-overheated-2001-obw-gonna-fix.html
This thread is intended to Supplement not replace the Factory Service Manual(FSM), I suggest you find and print out the Engine Mounting section within the Engine Service Section.
I found what I needed here:
Busted Finger Forums • View topic - 2000 Subaru Legacy Service Manuals
I would like to point out at this point, that I am 50 this year, I have never owned or worked on a Subaru before, but am a reasonably experienced wrencher.
Having said that, I did this completely solo, with no help.
My GF was close to hand and kept me under her watch and supplied with Coffee.
It took me about 4 hours, but maybe 3 actually working...
I bet next time I could do it in 2 hours.
I am better equipped than some, having a Kwicklift Ramp, but it is not needed for this job.
Before I start, here is the important stuff..
1/
Firstly, and most importantly, SAFETY FIRST!
I am going to assume you have a brain, its functional, are reasonably fit, and you have some basic skills here.
You will be raising/supporting the car, and lifting the engine out.
Both of these operations are easy and safe if done with the right equipment, and technique, but you can and will kill or injury yourself, or someone else if you are not careful.
WEAR EYE PROTECTION at all times!
Wear hand protection, if you might be allergic to oil or coolant, or if you like clean hands.
If you are unsure, get advice or help BEFORE you start.
2/
Store and Dispose of waste oil and coolant properly!
Please remember that Dogs and Cats love the smell and taste of Coolant, and they will drink it and DIE a painfull death if they do.
Drain it, pour it into a sealed container, and clean up spills.
List of Tools and Equipment Needed:
Safety Glasses!
Metric tool set, with 1/2" drive and 3/8 drive socket set.
10, 12, 13, 14, 17, 19, 22 are the most common sizes and I suggest both shallow and deep sockets are best in these sizes.
Metric Wrenches.
Screwdriver set.
Metric Allen Wrench set.
1/2" Drive Breaker bar.
Jack
Jack Stands(2), but 2 sets(4) is better
Engine hoist, Chains, Load Leveler.
Paper towels.
Oil catch pan(for Oil Draining)
Pan or Bucket (for coolant Draining)
Engine stand(Optional)
Movers Blankets(Optional... you gonna be on the floor.. floors is cold!)
Ziplock bags. Gallon and Quart size(To bag... trust me this is IMPOTENT).
Sharpies(to mark and label parts).
Digital camera(Cos I also used to have a Photographic memory, but they stopped making the film).
Disposable gloves(Optional if you like to keep you pinkies clean).
Mechanics gloves(Optional, if you like yor hands unbruised).
Hand Cleanser(Optional, to keep your partner or Boss happy)
Before you start options:
I suggest you buy some Engine degreaser, and WD40, put on some old clothes and go to your local pressure wash style car wash.
Spray the degreaser on the whole engine and let it do its job for 10 mins, then CAREFULLY wash all the grime off.. Try not to wet the electrical stuff!
After you are done, you have the WD40 to hand if anything got wet...
A/C system should be evacated according to the FSM, Read my comment in step 18/ and decide now how you want to proceed.
If you have a OBD Code reader, check the codes now, or get it checked right before you take the motor out.. You might have a code stored, that has nothing to do with what you do next. Better to know.
1/
2/
Safety Glasses!
Metric Wrenches.
Screwdriver set.
Jack
Paper towels.
