06 Outback 2.5i, 06 BMW 325xi wagon, 02 2.5rs, 82 CB750, Polaris XC SP 500, and a single speed bike.
This is on a 2005 Outback Limited w/ 2.5 and 4EAT.
As soon as the vehicle is put into gear (forward or reverse), the trip odo changes to ER IU. I've tried resetting the battery, turning the key on 30 seconds and then starting it, and nothing changes. Key off and back on again will clear it until it's put back in gear.
No CEL in engine or trans modules according to FreeSSM.
There are a couple functions that don't seem to work: inserting and removing the seat belt buckle 40 times in 30 seconds to turn off the seat belt warning doesn't appear to work, and I can't pull codes through the cluster either (lights on, push knob four times, lights off, etc). Not sure if anything is supposed to happen if there are no codes stored in memory with that function though.
I'm trying to fix this as cheaply as possible since I'm flipping this car following head gasket replacement a few weeks ago. Any thoughts on where to start diagnosing this one? Thanks.
