2009 Outback 3.0R
Hi guys,
does anyone knows the diameter of the exhaust ports on 3.0 engine?
I got some headers and curious if they match the opening without having to remove mine.
2005 Outback VDC limited 3.0r
Hi guys,
Are they specific to the ez30d? The earlier ez30 had a single port and obx made headers for them, the wont work with the later 3 port ones in our ez30d.
2007 3.0R Outback 5EAT SI-Drive, Push Start JDM 130k km
Hi guys,
I have an OEM EZ30 3 port exhaust gasket on the bench for a 2007 3.0R. The internal diameter of the 3 large holes on the gasket is approximately 44 mm. Hope this helps.
2009 Outback 3.0R
44mm diameter holes seem to me very large more like an intake size. Can you confirm that it is for a 3.0 not for a 3.6? Thanks!
From what I got it looks like I still have to compare to the actual ports size as gaskets vary in size and usually are larger than the port opening.
I need to fix the steering boots so good opportunity to check.
2009 Outback 3.0R
I can confirm that the OEM exhaust gasket ports are almost 44mm. I'll find out next week how large the actual ports are.
