Hello Subaru folks,
first time posting here, please be gentle with me!
I've got - what we'll call for now - an '02 Outback with about 40,000 miles on the clock. Plugs recently replaced, new s-belt and idlers and tensioner, fitted with a K&N Apollo intake system, and ceramic coated headers into a high-flow CAT and muffler.
It's been in the vehicle and running for about 1,000 trouble-free miles, but suddenly has developed a *very* subtle rough running / vibration issue.
At idle I can ever-so-slightly perceive a bit more vibration than previously, and at highway speed I can feel it as an ever-so-subtle low harmonic... even my rear-view mirror is vibrating a bit from it.
I have no CEL, OBDII tests through the Torque Android app come back clean. No change in available power that I can perceive.
No odd noises, no leaks, etc that I can detect.
I know it's the engine and not suspension/wheels because I can de-clutch and the vibration goes away. Also I can feel it very subtly at idle.
I've checked all fasteners, mounts, etc to rule out something just being loose.
In my old-school carburetor mind I would take a wild guess of a dead cylinder, but this is not indicated in the OBD tests as I stated above.
If anyone has any ideas or tips with where to start and what to check (either physically or with Torque/OBD) let me know!!!
now, here's the kicker... this engine is actually in a 1987 Volkswagen Vanagon Syncro... but the entire engine and wire harness and ECU and all are just as they were in the original Outback...
