1 - 12 of 12 Posts
15 OB 3.6r
I'm looking to see if there is a fog/light switch that fits into the follow locations? Circled in red.
I found the fog switch that's located upper right, but that won't work.
My 15 and 18 both have the factory fog light switch on the turn signal stalk.
15 OB 3.6r
same with ours. I was hoping there was an option for a button so I can add a light bar
2018 2.5 Outback
15 OB 3.6r
I have a base model 2018 2.5i that didn't come with fog lights. I just purchased the factory fog light switch and bulbs from the bay, and plug and play. All wiring in place already. The switch is pricey, but is factory, and could be wired to fogs or light bar if willing to run new wires. https://www.ebay.com/itm/2015-Subaru-Outback-Fog-Light-Switch-OEM-NEW-H4510AL100-/322441190147
Where does that switch mount? Is it in the same spot as my picture in the first post? On our outback the top row punch outs are longer rectangular and the bottom appear short rectanguls. I think that switch only fits on the top row???
I need a switch for the short rectangle spots on the bottom row.
2016 Outback 2.5 Limited
What does the service department say?
2011 SSM Outback 2.5i Premium
The installation instructions show the installation of the switch, they are linked here - https://subaruonlineparts.com/subaru-outback-lamp-p-3706.html
15 OB 3.6r
Discussion Starter #8
15 OB 3.6r
Discussion Starter #10
So a little update, I pulled the dash/switch area apart an it looks like the switch I need has to seat in the electrical panel behind the dash panel. They are not held in by the dash panel itself.
I think the two spots I have available are for lane change warning and collision avoidance (not sure what it's called) Without cutting into the factory electrical panel wiring I am not sure it will work as planned with the fogs...
Did you end up installing the switch in your preferred location? How was the install?
15 OB 3.6r
Discussion Starter #12
No I didn't. using switch that was on the wiring harness for the aftermarket light bar. Didn't want to pay the money for the OEM switch
1 - 12 of 12 Posts
