The facts:
Rebuilt the ej25d in my 96 outback, starts and runs fine, vacuum is steady at 16 inhg, new o2, new maf, new ckp, fpr is not leaking, runs smooth as silk all the way up to 2500 rpm then falls flat on its face with no power at all. No codes set
The parameters:
Above 2500rpm timing is at 40 degrees btdc and stays there, o2 is reading very rich at .9v, below 2500 it still seems rich but will switch like its suppose to.
Extra:
I reset the ecu after installing new maf and seemed to run better, then got worse, then went back to the same.
Ideas:
Car also has map sensor but seems to be working ok (no strange values that dont make sense)
Plugs and wires (reused the old ones that didnt look bad)
Injectors not atomizing fuel (stock injectors)
Timing (since vacuum is good and it runs smooth under 2500 i dont think this is likely)
Knock sensor (least likely since timing is at 40 btdc)
Any ideas? Anyone else have this problem?
The parameters:
Extra:
Ideas:
