Whats your favorite oil?
  • Mobil 1
    Votes: 136 45.2%
  • Amsoil
    Votes: 35 11.6%
  • Castrol
    Votes: 40 13.3%
  • Pennzoil/Quaker State
    Votes: 26 8.6%
  • Valvoline
    Votes: 21 7.0%
  • Redline
    Votes: 8 2.7%
  • Royal Purple
    Votes: 9 3.0%
  • Kendall
    Votes: 1 0.3%
  • Shell/Rotella T
    Votes: 11 3.7%
  • Other, Please Specify
    Votes: 14 4.7%
1 - 20 of 71 Posts
SubaruOutback.org Founder
2021 Outback Limited 2.5L - 馃崷The Ice Cream Man馃崷
What is your favorite oil? Do you use petro oil or synthetic? Also if anyone has any experiences or thoughts on this subject please feel free to jump in:D
Superb Moderator, ,
MY12 WRX, MY07 FXT
Mobil 1 5w30 since 2,200 miles. Nothing but good things to say about the oil, and the cheapest I've found it is at Wally World. Now it comes in handy five quart jugs.
2003 H6-3.0 Wagon (non-VDC, non-LLB)
Doesn't Subaru specify synthetic for the turbo models? If so, I'm wondering what brand/weight the dealers carry for servicing those.
synthetic at 2,200 miles?
I'm rebuilding an ea82 and I had the bright idea that I would run synthetic right off the bat. All the motorheads I mentioned this to flipped out and told me **** no. Standard protocol says you shouldn't run synthetic until your third or fourth oil change. If you swith to earlier, the rings won't seal properly and your engine will be forever plagued with low compression and blow-by problems.
...at least that's what they tell me anyway :p
I've always been curious if anyone has actually compared a car with synthetic introducd early to one that was switched later. I always thought it had a hint of superstition to it....but I waited till 6k on our 2003 outback just in case.
Re: synthetic at 2,200 miles?
I've heard the same also, in my '03 OB I switched to Castrol Semi-Syn at 4500 miles and will change to Mobil 1 full syn at 10,000 miles. I know people who have changed to full syn at 1000 miles and have had no problems. Still as a former mechanic myself, I'd say just wait. Most tell me its optimum to change it anywhere between 10-20,000 miles but the decision is your of course:)
That was true once, and might still be true depending on your engine. Not sure of the ea82, but if you are rebuilding a older small or big block Chevy you will run dino oil first.
Now consider that Mobil 1 is the factory lubricant on Porsche and Chevy Corvettes.
Superb Moderator, ,
MY12 WRX, MY07 FXT
Let me tell you that I researched it entirely before I did my first oil change @ 2200 miles to synthetic. As you know, the seals need to be set, and certain other components break in better with dino oil. I was told that at my first oil change it would definitely be fine to switch. Third or fourth oil change? You could have up to 15k miles by then, that's getting a little silly. I still have yet to see any harm done to any engine by changing to synthetic before even 1k miles. Everybody talks it but I never have seen/heard any real proof when switching to synthetic even around 1k. Brian
Liberty/Legacy 3.0R spec B
I am a fan of the Amsoil oils. I have been using them for years, but I maybe switching to Neo, as my local agent for Amsoil also sells this brand and he assures me that the diester based oils are the way to go. Unfortunately it is super expensive here in Oz. I may give it a try and see how I go, but I have to wait till my new spec H6 Outback 3.0R is about 10,000kms old and I've only done 5,500kms in the 2.5 months of ownership.
MY99 3rd Gen Outback GX, 2004 Lexus RX330 Sport Luxury
Hey Lance, can I ask what viscosity and grade of oil the Subaru Owner's Manual recommends for the H6 engine ?
5W30 is preferred according to the manual, but it will be fine on other grades like 10W30 and 10W40 etc.
I see. So it's identical to the H4. ;)
Yes, I think you're right. I do believe they make their engines to the same tolerances, so therefore need the same oil viscosity.
Discussion Starter · #14 ·
Well the H6-3.0 is just a 2.0L with 2 more cylinders. I wish they would make an H6 as a bigger version of the 2.5L, just imagine a 3.8L H6!
Even better a 4.0L H8, or even a TRUE 5.0L H8! When I say "TRUE" I am referring to a Mustang with a 4.9L (no its not a TRUE 5.0L) V-8, it can't even round up to being a 5.0L.
Sorry for the slight OT, let us proceed :D
2004 35th Anniversary Outback - H6
on my race motor i run Mobil 1.. motors build by ROUSH thats what they recomend... i wouldn't agrue with that ;)
i also use valvoline on some of my other cars... thing is i think i use it because of this ;)
Discussion Starter · #16 ·
I don't care for Valvoline... but thank you, thank you very much for those nice pics! :10: I think that first girl is my future ex-wife :D
synthetic oil
Personally I can't see why you'd use dino oil initially, have owned a few BMW's in the past and from 98 on they only change the oil every 15,000 miles or so, motors seem to last very well. Of course engines aren't an exact science, so who knows, maybe there's a benefit having some impurities there early on...:cool:
Discussion Starter · #18 ·
Re: synthetic oil
The standard oil picks up and deposits all the impurities found in the engine that were left there from the factory better than synthetic oil. Ya know, the metal dust and all sorts of other stuff that can be deposited throughout the engine when it is being built. Petro oil just soaks that stuff up better, that is the only reason I've ever heard. Also most lower dollar engines that use synthetic from the factory probably have different seals and whatnot that are designed to break in better under the useage of synthetic oils. A mainstream company like Subaru would be one that would have those seals that need to adapt, if you will, to the dino oil first before switching to synthetics. I know that Subaru does not use any break in oil like many other companies use as a factory fill in all their new cars so I don't really know in their case. That information I just shared on oils, seals, etc it what I was taught as a mechanic so take it for what its worth.
Without the use of break in oil it would probably be fine to switch to synthetic oil whenever you'd like. Although I'd still reccomend not switching to synthetics on any part of your drivetrain until 10,000 miles :)
synthetic oils
Ahh I see, thanks Cao Cao, I stand enlightened. PS I also forgot to mention that the new BMW's all seem to specify only Mobil 1 to be used in order to get their long 15,000 mile oil change interval.:eek:
Discussion Starter · #20 ·
Also, like I stated in my previous post in this thread, I used Castrol Semi-Synthetic at my first oil change at 4500 miles. I'd say thats the best way to transition your car from petro oil to synthetic.
Also I'd like to add my favorite oils:
Petro (Dino) Oil: Castrol GTX or Castrol GTX High Mileage
Full Synthetic: AMSOIL or Mobil 1
1 - 20 of 71 Posts
