I'm currently changing the head gaskets on my 99 OBW. I decided to go with the Felpro MLS. The problem I had is that they come in a kit with all the other gaskets and sell as a PT-2 or PT-3 and nobody had an answer as to which one I needed.
I contacted Felpro directly and they emailed me a PDF explaining the difference. The only difference is in the valve cover gasket. Mine is a PT-3 which has a wider base or flange on the side going into the valve cover.
If you look at the attached diagram you'll see a hand-written diagram. Imagine that as if you cut the gasket in half and was looking at the cut end.
