2007 Chrysler 300C built 5.7
I got a similar one for a gen 4. The spring that flips the key could be stronger but other than that it's perfect. Swap the guts from your fob to this key and get it cut. Should work just fine. Be careful when taking the flip key apart! It can be kind of a pain.
2000 Outback
Thanks for the input, but it doesn't really help, cause the case is a for a 1994 legacy and it says nothing about the 1997.
I has car.
If the blade pictured is the one you're getting, then no, it won't work for a USDM 1997 model. Wrong keyway.
Blade pictured is a X237/DA34 10 cut keyway which is used on 2nd gen Outbacks. You'd need the X210/DA23 8-cut key.
I do not sell in my shop nor reccomend the 'remodeler' flip keys sold on eBay. They're junk, IMHO.
