1 - 7 of 7 Posts
2009 Subaru Outback 2.5i PZEV Special Edition
Hey all audio nerds!
My Scosche BT-FM transmitter unit emits a ringing noise/high hum that seems to be related to the RPM of the engine, the higher my RPM the higher the pitch of the hum and vice versa - lower RPM, lower hum. This doesn't happen if I plug it into the AUX port of the car, only if it is FM transmitting mode. Does this mean that there is a larger problem in the electronic system of the car (grounding?)
TIA
Bobby G
2015 Outback Limited 2.5 & 2019 Outback Touring 2.5
Is it possible to try a different frequency? If not, usually you could try ferrite clamps, capacitors, or various noise filters.
Noise Filters
Noise Filters
I didn't even know 12v noise filters existed, Thank you!
2012 OB , 2017 Impreza
If the noise follows the RPM of the engine, it is likely noise from the ALTERNATOR. (ignition-noise is more like a "static" sound)
Back in my younger days, when I was into car-stereos, I would have to deal with alternator-whine. An electronic "filter" between the +12v feed and chassis (as close to the stereo as possible) would dissipate the noise.
Often, a properly-valued capacitor between +12 -and- ground would be sufficient. Sometimes, I added a choke (tuned to the frequency of the alternator-whine) in series with the +12 feed.
If you are not into electronic circuit design, you can simply purchase a premade "filter" to install on the power-feed of the radio. The main specification to be concerned with is the current-rating for the "filter" is higher than the radio can draw.
Use your favorite web-search tool to look for "12v noise suppressor" or "12v noise filter"
2010 2.5 CVT Limited
Wouldn't it be better to put the filter on the power feed of the BT-FM adapter? Nip it at the source.
I thought that the alternator might be the cause of the problem. I will look into adding one in once the weather is warmer lol
1 - 7 of 7 Posts
