1 - 10 of 10 Posts
Well I've been dealing with a pp440 code for awhile. I heck all hoses and the canister with no luck. He culprit? A rusty gas tank. The tank is rusted out at the weld in the front of the tank just above the drive shaft. Suggestions on fixing this without removing the tank( seems like too big of a job for me) thank you in advance squirrel
Depending on how much rust there is (the size of the area affected), and the room you have to make a repair, you may be able to clean the outside of the tank up enough to JB Weld the area or fiberglass over the damaged section.
The tank will have to be almost empty (gas level well below the weld seam) and use only sand paper or die grinders with discs that will not spark on the steel tank. Once cleaned, you should be able to cover the area with a thin application of JB Weld, fiberglass cloth and more JB Weld on top, or just fiberglass resin, cloth and more resin (2 or more layers) and let harden.
Depending on how large the area is and the shape of the rest of the tank, your best bet may be to put in a used tank. Be prepared for the tank straps and various bolts to all be rusted and need replacing. Good Luck!
Please don't repair your old tank, empty fuel vessels are more explosive than full ones, what starts fires are not the liquid fuel but the vapors, the liquid only serves to fuel the fire once started.
I'd be getting a good used or new and doing a complete replacement.
1999 obw 2.5l Auto 194,000 mi
also the ethanol in fuel can cause the resin in fiberglass to dissolve and get into the fuel system so dont fix it that way.
'99 Outback 2.5 GT auto & '97 LegOB w/ grossly insulted 2.5
Here in the South, gas tanks are a nuisance, as there is very little rust damage, short of those who 'surf' their Subies & scrappers won't accept them. You might inquire to user Lockmedic, or others down here who part Subies
2010 OBW limited 2.5 CVT
Just be aware that used tanks won't be available from scrap yards and cannot be shipped if there are any fuel odors at all. Salvage yards are required to drain tanks and do so by putting large holes in the bottom. Only new tanks can be shipped, so you would have to get a used one from someone local parting out a car.
Fresh Out of Outbacks!
after removing and draining a gas tank, you can remove the trace fuel vapor by dumping a bit of dry ice in. the dry ice sublimates to co2, which pushes the fuel vapor out.
1 - 10 of 10 Posts
