Hi !!
I am new here and i just buy an outback 2007 ( i live in dominican republic).
The cruise control do't work and at start engine no cruise ligth on (only set ligth)
I checked wirh freesmm softaware and here the result :
FreeSSM v1.2.5
Tuesday, 23. April 2013, 18:52:
Control Unit: Engine
System Type: 2.5L SOHC
ROM-ID: 4B 22 14 80 07
Registered VIN: 4S4BP62C277302594
Temporary Diagnostic Trouble Code(s):
----- No Trouble Codes -----
Memorized Diagnostic Trouble Code(s):
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
Latest Cancel Code(s):
64 Engine Sensor Failure 1
Memorized Cancel Code(s):
The 64 engine sensor failure 1 ,is in the Cruise control section........
...well really need help...here mecanics always say: That is only for US owner...here not necesary !!!!!
Thank you anyway and sorry for my bad english !!!
Italo
For North American Outbacks, the DTC 64 is indicating that the cruise function was "cancelled" because of a malfunction in the engine.
"DTC 64 Malfunction related to engine is detected."
This might be related to the P0037. The P0037 is a memorized (inactive) code. Use FreeSSM to clear the code(s), and then see if the cruise control function resumes.
If not, it could be a broken connection in the clockspring connector (under the steering wheel). There was a similar case here not too long ago: http://www.subaruoutback.org/forums...cs/49031-2006-outback-cruise-not-working.html
By the way, I didn't realize that FreeSSM can show Cruise Control diagnostic trouble codes. That's a plus.
Thank you very much !!!
I'll try to clear code and i'll see what happen....thank you again,i know that i can have more posibility to resolve my car problem with forum help that from a mecanic here in RD !!
Well ,subaru dealer can help but....you go with a bulb ligth burned...and they change 1/2 car !!!!
Thyank you,i ll back here with news about my problem!!
Ahhhh "By the way, I didn't realize that FreeSSM can show Cruise Control diagnostic trouble codes. That's a plus." really i don't know...i clicked on Cruise control and i could see the error report!! :)
Hi !!
Today clear the message code memorizeded with fressm .......but cruise control light is not on when i put ignition swith on.....only set light.
I think,after read the link http://www.subaruoutback.org/forums...cs/49031-2006-outback-cruise-not-working.html .......that i have same problem,i'll ask to a dealer here if they can help me with check clockspring.......or i 'll need buy it in US and change it for myself :(.
ty !!
