Front center jacking point
51031 Views 9 Replies 8 Participants Last post by  patrikman
Rear is diff., what about front ?
thanks
1 - 10 of 10 Posts
thanks
Doubt there is one up front. How do you know the rear diff is an OK rear jacking point?
There's a jacking point at the front.
The rear differential is another identified lift point, but I've always wondered about this. The differential is attached to the subframe by rubber bushings, and when the car is lifted at the differential, the bushings are compressed a lot -- seems to me that can't be good. But it is a recognized lift point, as the Service Manual notes -- see attached, which is from the 2010 FSM, General section, Note sub-section.
Reactions: 1
Thanks. Do you have the diagram that shows the points when using a car lift? I just guessed and it seemed to be fine, but there ain't alot of stout material under there.
When using my floor jack, I have always use those jacking points on all my subarus
. . . Do you have the diagram that shows the points when using a car lift? . . . .
When using a car lift with swinging arms, the arms are set to contact the car body at the same place (four points under the sill) as when lifting with the car's own jack (see Owners Manual).
A flat piece of rubber should be placed on the swinging arm pad to protect the bottom of the pinch weld; better still, a solid piece of thick, rubber with a channel in it (as in the attached diagram) is used so that the weight of the car is supported by the reinforced areas of the rocker panel to the side of the pinch weld and not the pinch weld itself (similar to way the car's own jack has a notch that slips over the pinch weld so that the jack doesn't lift on the pinch weld itself).
Bumping an old thread instead of starting a new one.
Has anyone used one of these urethane jack pads to protect the pinch welds when jacking up the car?
1 ea Universal Blue Floor Jack Disk Pad Adapter for Pinch Weld Side Jackpad | eBay
Seems nice... But I still use ordinary hockey pucks at 1/7 the price from the sporty store up the street.
Since the thread was bumped, what kind of lift range is needed with a floor jack? I need to get a new one and want to be sure I have enough range to get the tires off the floor.
I use scrap chunks of 2x4. Not sure about later models but I jack under the crossmember in front. Right about where there are two bolt holes for the crappy plastic OEM splash try that gets torn off regularly lol.
I can take a pic of you don't understand where I'm talking about.
And yes, I jack in the rear right under the diff. Wood block. I kinda put it across the rear diff so it doesn't just lift when the bushings are squashed.
1 - 10 of 10 Posts
