i drive a 98 legacy outback 66kmiles.after i've been driving around quite a bit, all things up to temp, i hear an intermittent horrible squeak at low speeds. It is definately induced and removed by braking. As in, i can lightly tap the brakes to make it turn on and off. could something just need lube? if so, what then?
Tokyo's between my toes
2001 Wintergreen Outback 5MT
My 98 did that when the front brake pads were due for replacement. I let it go until I heard a grinding noise; look that thread up and you can see a pic of one of the pads I took off.
:eek:
Lord of ScoobyMods, ,
19' Impreza Sport 5 dr / 01' Forester S / 13' OB CVT / 10' Legacy 3.6R / 99 Mita MX-5
sounds like you are at the wear indicators, better change the pads or at least have them checked out ASAP before you need rotors too.
