I need to replace my front transverse links since the bushings are leaking fluid (rear control arm bushings). Is this possible to do without removing the control arms from the car. Looks like if you can break the bolts loose and undo the transverse link mount bolts it might be able to be slid off the control arm with the arm still in on the car https://trackeasy.fun/usps/ https://showbox.tools/. Has anyone done this without removing the whole control arm off the car?
03 H6 OBW & 06 WRX Sportwagon
I did what you describe to my '03 . You likely need an impact for removal as well as a big torque wrench for 'proper' installation. I used Febest replacement parts from Amazon, much cheaper than OEM. I first had tried Prothane poly bushing inserts but they were too harsh for my wife's liking.
You will want to research the process but it's doable.
01 Outback LL Bean
It is doable. Make sure when you tighten down the new bushing nut that the vehicle is at static ride height. Either jack up the control arm at the ball joint until it is off the jackstand or tighten when it is on the ground. Its a good idea to mark the alignment of the current bushing to the control arm if you take the arm off so you can align the new one.
