Hey all,bheinz57 said:Hello, first thing to check is the connector under the hood on the pump which is on the reservoir for the fluid. Make sure that connection is good. Then maybe check for power going to that connection, maybe the pump went out. The last thing will be the most expensive...the switch on the steering column. A lot of small wires in those plastic tubes we use as levers. Good luck. Brian
