1 - 2 of 2 Posts
1997 Subaru Outback wagon, 214K miles, 2.5L motor, 5 speed manual transmission, full time all-wheel drive, cloth interior, exterior is white.
This car is in great condition - it came from Colorado, doesn't have the typical Minnesota rust spots on it. The motor has just been redone completely - here's a list of all the brand new parts that just went into the car:
Head gaskets (with new head bolts, not reused ones)
Heads were resurfaced professionally before being put back in
Timing belt, including all idler pulleys and tensioner pulley
Water pump and thermostat
Radiator
Clutch kit (clutch plate, pressure plate, throwout bearing, pilot bearing)
Front and rear brake pads
Spark plugs and wires
Rear main seal
Oil pan gasket
Cam oil seals
Valve cover gaskets
Intake and exhaust manifold gaskets
Knock sensor
Oil pressure sensor
Fresh oil change and fresh coolant
Also, has newer starter, alternator, and battery cables.
Car has power windows, power locks, nice new rubber floor mats, trunk liner, fog lamps, AM/FM radio with cassette.
The tabs are good through October 2013.
Asking $3500/OBO.
Email or call Brian at 763-744-6326.
1 - 2 of 2 Posts
