1 - 20 of 27 Posts
2013 OB 2.5i Premium/DDD Graphite Gray Metallic OP#2 Weathertec Window Deflectors
Has anyone used this on there oil pan, if so pros & cons would be great.
Does the dealer's handle these? Or just on the net, can't find them in auto parts stores.
I've installed them on the last four vehicles I've owned. Haven't got one for the OB yet since I just bought it. No problems with clearance or any concern of it opening on its own.
However, you order the Fumoto valves online. Never seen any in the store or dealer. It makes changing the oil easy and clean for me as I do my own servicing.
2003 OBW 2.5L 4EAT
The bolt thats on the pan isn't magnetic either. I have a Fumoto valve on the Forester and i've used it twice for oil changes. It makes it quick and easy for oil changes.
2005 3.0 R n totaled
2012 Outback Premium Ruby Red Pearl 2.5 CVT AWP
I have had a Fumoto on the last 4 of my vehicles and is the very first thing I do when I get a vehicle. I have always been afraid of stripping the threads in the pan and the Fumoto is the perfect remedy for that. The only negative I can say is that it does drain slower than if you had the OEM bolt. Other than that, they are great.
2012 Outback 3.6R
I have found the slower drain is not an issue. The first thing I do is put the hose on the Fumoto and secure to my drain pan. Open Fumoto then I do the oil filter and check all other fluid levels except of course the transmission. By then the oil has drained, close Fumoto and refill with new oil.
The Subaru Drain plug uses a compression ring. The first time and only time you install a Fumoto valve do you install a compression ring along with the Fumoto?
I added a Fumoto valve for the first time on my 2013OB. I got it with the nipple and hose for <$30 on their website. Cost was about $26, with the nipple and hose add$3. I was concerned about the "hangdown" exposure with the nipple but after installation have no regrets or worries. The front sway bar sits lower right behind it and is substantial. I feel it would take a miracle shot to do any damage.
The install was uneventfull and I used the provided washer. The factory pan bolt was on tight---really tight, as it is painted over. The valve itself is of high quality- it is a really nice product. You can easily and cleanly drain in to a recyclable container. Must have for the DIY'er.
Willy999, like OBnube said the Fumoto valve comes with a compression ring, although I've read some people have issues with slight leakage. In that case, you can just get the OEM crush washer and use that when installing the valve.
Mine did not come with what I would call a compression ring. It is a fairly thick hard "gasket' like material. Very little to no compression. Maybe that's where some have a leakage issue. Tight and dry here.
2004 Outback Wagon, 2.5, 4EAT, All weather package.
Nah, the ad on the bottom of this page for me on my work computer is Midas of Kalkaska. I don't know why Kalkaska (in Michigan), I live in Pittsburgh, PA...
Discussion Starter · #19 ·
Thanks for all the comments, have another question, using the valve and it is slow to drain as many have stated. Do you think less gunk is being drained out of the oil pan, or more sediment staying in the pan with no real force to flush?
One thing to watch out - if and when you have a dealer do an oil change I can guarantee that they will try to bill you for the oil plug seal/gasket even if you have the Fumoto valve installed and even if you warn them, when you turn your car in for this service. This is because they have it pre-programmed in their databases. You should therefore scrutinize the bill before paying it. I had that issue over and over, not just with Subaru dealers but with Honda, VW etc etc.
1 - 20 of 27 Posts
