It should be fuse number 13 (20 Amps).
Can this fuse be found under the hood or inside the drivers side fuse panel?It should be fuse number 13 (20 Amps).
Did you refer to the manuals I linked in my first reply? Page 12-10 is the beginning of the fuse listings for the different fuse panels (found this using the index at the end of the PDF). Yes, fuse 20 in the dash fuse box is for the accessory power outlet.Can this fuse be found under the hood or inside the drivers side fuse panel?
Thanks for info. I misplaced handbook, and I am scouring the garage for it now. Thanks.Did you refer to the manuals I linked in my first reply? Page 12-10 is the beginning of the fuse listings for the different fuse panels (found this using the index at the end of the PDF). Yes, fuse 20 in the dash fuse box is for the accessory power outlet.
If you didn't get the book with your car, it might be handy to download it from the link I provided above, it has all this info in it.
