So on my most recent trip and with a little cooler conditions (55f-20f) I started to experience a really fun issue. It usually happens in the morning when the car is cold but basically, I will start driving and somewhere down the road (within the first 20 minutes of driving) I will shift gears (any gear, up or down) and my gas pedal will quite working and my car will try to idle at about 2k Rpm. I then have to coast or if I am stopped clutch bump my car to the side of the road. I have to turn off the car and let it sit for about a minute, I will try to start it once and it won't go, give it a second shot and it works like a charm as if nothing happened...
I would like to try and figure this one out as it can be a little sketchy as I am sure you all can imagine...
Ive done a little research and it sounds like it could be the throttle control harness, its just odd that I have only experienced this problem in slightly colder conditions...
Any help or ideas with this would be great!
