1 - 9 of 9 Posts
04 Outback H6
So I have this interesting problem.
Fogs work
Highbeams work
Lowbeams do not work
Daytime running lights do not work
Parking brake switch appears to work (the parking light indicator on the dash comes on and off)
Fuses look good (in both the Fuse Block and the Main block under the hood)
Any ideas?
I'm leaning towards getting a new DRL relay to see if that will fix my problem.
2001 VDC Wagon
Have you checked the bulbs? You could unplug the DRL relay to see if something is giving you trouble there.
04 Outback H6
First thing I did was replace 1 of the bulbs and it didn't do anything. Then I noticed the DRLs weren't on... which I found odd.
do the gauge lights work at night?
I've had an odd failure that is intermittent; the DRLs are off and the gauge lighting is extremely dim at night. Then, for no apparent reason, back to normal.
weird
The DRL module controls lighting for DRL and low beams because it alters current for each. There could be a problem within the DRL module or your multifunction switch. I've attached wiring diagrams for a 4 light setup. If you have a 2 light, PM me so I'll get an e-mail notification and I will post that one.
04 Outback H6
weird
Gauge lights are fine at night. I just run the fogs (since my lows don't work).
Also I replaced the DRL module with another one I bought off ebay and it was still the same.
Ebay = used?
If so, that's just about like saying you tried a broken part to see if your part was broken too.
Got a test meter? Check for power when the switch is on, at the bulb connector.
Well, its time to pull the DVOM out and start tracing wires. You have the diagram above. I would start with checking ground and battery at the bulb and work backward.
04 Outback H6
So apparently it was actually both the bulbs burnt out.
The first replacement was bad which threw me off.
BTW for anyone else, the daytime running lights ARE the low beams. I made the mistake by thinking they were the high beams.
1 - 9 of 9 Posts
