1 - 7 of 7 Posts
Hi there (first post)
Ive ordered my ‘23 XT Touring to be factory fitted with trailer hitch, but I’d love to know how many connector pins are there so I can narrow down my caravan choices.
Thanks in advance :)
Present: 2023 Premier XT, 1990 Corvette; Past: 2015 Impreza 5MT (going to miss the 5MT)
My Premiere XT was built in the US so there may be different standards from those built in Japan. But:
I did get the factory hitch installed but it only came with a four pin connector, left, right, brake and ground. If you need a seven pin, which includes those pins and 12VDC, brake controller and reverse light, here in North America, you're on your own. The reverse pin on the Gen 5 OB internal connector could be found on connector R79. Apparently, this is not so for a Gen 6 OB. If I do go 7 pin, I will route a 12VDC line and a brake controller line to the back and route a manually switched 12 volt line to use for reverse lights.
Does the 7 pin rectangular come with a reverse light pin?
Hmmm....
I wonder where they took the signal from? Maybe the wiring harness is different than NA built models.
1 - 7 of 7 Posts
