So I need to eat some crow here. Most of the vehicle is just the 6th gen outback. That eyesight system however is new. It appears to mostly be eyesight X witha few missing feature. Likely due to not have the detailed street data that they do in Japan. Just a guess.Everyone needs to realize all this is is the current gen outback making its first Australian debut. I went over the whole thing and the only thing new there is the speed Sign Recognition which actually seems really awesome and I hope it comes the US MY22 models. Other than that the differences are probably caused by how they measure it there.
This is very important to remember that Toyota HAS bought into Subaru and there is some back and forth transfer of technologies. Some of this is Toyota helping with the Hybrids, and then Subaru helping with the CVT's. I am sure there are other things that they both share back and forth.I suspect the speed sign recognition is a by product of the Toyota part ownership of Subaru.
The Toyota Corollas have had this technology in Australia for several years now.
Seagrass
Just a few weeks ago I test drove '21 Onyx and Limited trims that had the speed sign recognition. I'm not sure what the cutoff point is for when it is included or not, but the Premium I ended up buying does not have it.Everyone needs to realize all this is is the current gen outback making its first Australian debut. I went over the whole thing and the only thing new there is the speed Sign Recognition which actually seems really awesome and I hope it comes the US MY22 models. Other than that the differences are probably caused by how they measure it there.
The current models pull the speed limit information from the navigation database and is known to be pretty horribly inaccurate. It also requires have a trim that includes navigation. This new system uses the eyesight cameras to read the speed limits live. So one can actually have confidence in it. Not sure what intelligent speed limiter means. Hopefully you can use it to set the cruise to something like 5 over the speed limit. It would suck if it only allowed for at the limit settings.Just a few weeks ago I test drove '21 Onyx and Limited trims that had the speed sign recognition. I'm not sure what the cutoff point is for when it is included or not, but the Premium I ended up buying does not have it.
Very much possible. It might even be less about technology and more about patent access. Who knows, but Toyota's feature is where I first heard of the option and have been hoping it comes to Subaru ever since.I suspect the speed sign recognition is a by product of the Toyota part ownership of Subaru.
Seagrass
Interesting, was not aware that was how it was working. I had a '20 RAV4 with the feature for a year and am still very much unsure how I feel about it. It was nice to be able to see the speed limit on the dash, but it wasn't perfect and would sometimes miss signs, especially school and construction zone signs or the variable signs they use in the mountain passes here in Colorado. It was just good enough that I got out of the habit of paying close attention to the speed limit signs, which was making me a bit concerned that I would get a ticket some day as a result. It was very good at recognizing stop and yield signs, but this was limited to one very specific screen in the CID that I never used. So I saw little benefit from that aspect of it. Plus, at a stop or a yield your head needs to be up and looking out, not buried in the dash. Toyota's system shows promise, but still needs work I think.The current models pull the speed limit information from the navigation database and is known to be pretty horribly inaccurate. It also requires have a trim that includes navigation. This new system uses the eyesight cameras to read the speed limits live. So one can actually have confidence in it. Not sure what intelligent speed limiter means. Hopefully you can use it to set the cruise to something like 5 over the speed limit. It would suck if it only allowed for at the limit settings.
Wow. I'm shocked that they don't have ventilated seats on the touring. Australia is, in general, closer to the equator than the US so it is hotter. I live in OKC which is at 35.5 Lat and I personally hate how hot the summers are here. Very much hoping the MY22 Forester has ventilated seats like the Outback and Ascent. Sydney meanwhile is -33.8 Lat so it is slightly hotter. Probably rare you get snow there. I would think ventilated seats would be important.Key differences I can see in the AU Gen6 compared to the AU Gen5:
- Looks like they've finally dropped halogen headlights, LED across the range now.
- The PDF brochure doesn't say it, but it implies that Adaptive Driving Beam is part of the LED headlights, ergo all variants, not just the top-end now have it.
- No mention of SRH on any variant, but that will have to still be there if ADB is still a feature as they work in tandem.
- Cladding is standard on all variants now (previously the Standard variant didn't get it, was an optional extra).
- We finally get a shark fin antenna to replace the awful rear-window integrated antenna that lost reception when your shadow moved.
- Heated steering wheel.
- Heated rear seats, previously only fronts were heated. No mention of vented seats again.
- 12v outlet in the cargo space is standard now, previously was a $70 extra accessory.
- We finally get RAB, all Subaru models in Australia have only received this as they moved onto the Global Platform.
- Slightly greater towing rating (up 200kg).
- EyeSight version 4 with the intersection and steering avoidance features, and the speed sign monitoring and haptic feedback for the steering wheel.
- Higher ground clearance matching the Forester.
- The Driver Monitoring System.
- 18" wheels across all variants (previously the Standard variant came with 17" wheels while the others had 18").
- The larger screen infotainment system.
- Sports pedals, previously we only had standard rubber pedals across all variants, even in the 3.6.
- Auto-folding mirrors when parked (previously had to manually press the retract button).
- Seat position memory now includes mirror position memory (previously didn't).
- Door mirror caps (previously the "Outback" strip along the side of the car would be chrome on the 3.6 and normal black plastic on other variants, and we didn't have door mirror differences)
- Everything else is as per Gen5.
Received my invite from Subaru for launch day, so will be keen to check it out in the flesh in a couple of weeks. There's already a couple Gen6's I've spotted driving around in Sydney, no doubt salespersons getting some driving time in them to get to know the new model.
Picked up an MY21 Touring on Thursday - quite impressed
[/QUOTE
Well done Scott, did you check the build date?, all the ones I saw were '20 build compliance, and why I have to wait till April to get my '21 built Autumn Green Touring.
Yep,This recent carsguide.com.au car news article dated 19-Feb-21, titled ‘Subaru Forester turbo unlikely, but boosted Outback on the cards!’ was linked to on the Whirlpool forum yesterday.
That is because I sent them an email about a month ago informing them of my displeasure. They clearly listened to meYep,
What's interesting is Subaru Australia's GM, Blair Read announced yesterday (about the 2.4)
More powerful Subaru Outback turbo on cards for Oz - motoring.com.au
Subaru has revealed that it’s working on a case to bring a more powerful 2.4-litre turbocharged petrol engine to Australia to crown the new 2021 Subaru Outback range.www.motoring.com.au
There are a lot of calls for the 2.4 turbo and we’d be silly not to be reviewing that option for the future.
Read said the 2.4 was not currently available to the Aussie market, but he made it clear that “we’re working on that”.
Yep........you weren't the only oneThat is because I sent them an email about a month ago informing them of my displeasure. They clearly listened to me. I think not but collectively if we all make rumblings it could happen. I will probably still replace my 2015 3.6 with a newer 2nd hand 3.6 at some stage.
But does the squeaky wheel get the turbo..............Yep........you weren't the only one, I've been banging on about it to SA for the last 2 mths,..........the squeaky wheel sometimes does get the oil.
In the US all SUV models (Outback, Forester, Crosstrek, and Ascent) are advertised as 8.7 in (220 mm) of ground clearance. Why would the Australian Outback be made differently?All models have alloy wheels and SI-Drive. Ride height is 213mm, same as Gen5. The Forester ride height of 220mm will be considered next year.
Wait, you are saying it can be permanently turned off on some models? In the US no Subaru that has it can permanently turn it off. You need to buy a $100 aftermarket solution to do that.Auto-stop/start is in all variants, but can be toggled off in the "Outback" (turns back on next restart) and turned off altogether in "Outback Sports" and "Outback Touring".
