2002 Outback VDC
Hi everyone, this is my first post after lurking for over a month. I bought a 2002 VDC and the headlights suck. Curious what H1 bulbs you'd recommend for my low beams. I ordered a set of Philips 9012 HIR before realizing those were for the fogs. My high beams are satisfactory so I still need a low beam upgrade. thanks in advance
Start with restoring the polycarbonate lenses. Sylvania has a kit which includes the important UV clearcoat as the final step. Keeps it from hazing over in 6 months.
You can get brighter bulbs. Vosla 27420 will work but won't last as long.
Osram 62200SBP is another similar item.
2002 Outback VDC
Thanks for your response. Fortunately my headlights are surprisingly clear, or are you suggesting that changing the light bulbs will lead to hazing?
I have to cover myself. All bulbs will cloud polycarbonate from the inside but at such a minuscule amount it is nowhere near as damaging as sunlight. Changing the bulbs will not cause the common hazing that we think of. I was stating that all polycarbonate headlamp covers are originally UV clearcoated to prevent hazing. After restoring by means of buffing, wetsanding, ETC, the offending haze layer is removed along with all traces of the UV protectant. I was pointing out the role of the UV clear after any headlamp restoration otherwise the haze will always return.
