1 - 2 of 2 Posts
2002 Outback LL Bean- H6
Looking for some advice on what all to replace here. I'm taking the extra time at home to do a little spring work on my daily driver. 2002 Subaru Outback LL Bean H6. This is a bit of a beater, so I'm only interested in keeping it safe a reliable.
It's gotten to making some clunks while driving over pot holes, and has a slight steering wheel shimmy at highway speed.
Looking at the front suspension, I found the drivers side ball joint boot is torn, so I'm planning on replacing that.
483836
Also I noticed a bunch of greasy slime all over the passenger side control arm rear bushing.
Are these grease packed? I thought they were just rubber.
Should this be replaced as well?
483835
Should I replace more than just the driver side ball joint?
Should I do both sides?
Should I do the rear bushings as well?
Anything else I should look at?
Thanks!
(Pass side ball joint)
483837
those rear LCA bushings are fluid filled. If they are 'just' leaking the fluid and otherwise good, I'd ride with them for a while. But, you can often have worn-out rubbber there that allows too much movement and sometimes clunking.
I did that job twice. Once put in Prothane poly , too harsh for the wife. At present have Febest after-markets on the car and so far they are OK. At the time , OEM weree priceey - dunno what the market is like now or if there are other new aftermarket makers.
1 - 2 of 2 Posts
