Wow!...that is a comprehensive guide...but not a DIY I will ever attempt.
Really nice!
Ideally I'd have access to a keystone clamp and OEM band. However, even the tech at my dealer told me they don't do that. They use zip ties as well due to the steering rack being completely encased. I *might* be able to get a standard hose clamp on and get a screw driver from the side (where the zip tie end was poking out). Will probably check it in a few thousand miles.Really nice!
The only thing I would caution you against is using zip ties for the boots instead of the proper clamp. It likely won't last and you will get a bunch of dirt in there before you know it.
...that would be just common sense...to put it back on the way you found it...if you're going to use zip ties...might as well pull out the duct tape too...lolReally nice!
I had to use those Oetiker type clamps alot in my environmental engineering days. nice clamps, but not so nice if you ain't got the proper tool. Should be able to source a skinny hose clam somewhere.Ideally I'd have access to a keystone clamp and OEM band. However, even the tech at my dealer told me they don't do that. They use zip ties as well due to the steering rack being completely encased. I *might* be able to get a standard hose clamp on and get a screw driver from the side (where the zip tie end was poking out). Will probably check it in a few thousand miles.
