Very cool album...looks like that project took some time!
...and sometimes just unplugging the coil pack is a challenge!I replaced my plugs from the bottom today and it wasn't too bad. The drivers side closest to the fire wall was the worst. Found that I had to unplug the coil pack on the drivers side closest to the fire wall to get the coil pack all the way out.
I would never try them from the top as from the bottom they are right there like JP said.
The engine does run a little smoother now.
I disagree with this advice in the first post. Anti-seize on plug threads is a bad idea. Use new motor oil.- Definitely use some sort of anti-seize on the threads.
Are you referring to the boot that contacts the plug from the coil pack? If so, I just pulled them off without rotating, though I'm sure it's possible that a little rotation could help.Did you have to rotate the boots to remove them?
Indeed, but I had watched some youtube videos of people doing the plugs on the H4. Totally different setup!Are you referring to the boot that contacts the plug from the coil pack? If so, I just pulled them off without rotating, though I'm sure it's possible that a little rotation could help.
They sure are! The H6 is coil-on-plug while the H4 is not. Plus, it is much easier to access the plugs on the H4. I can get to both sides very easily from the top as long as I move some of the air intake stuff and the washer fluid reservoir out of the way. Definitely not the case with the H6!Indeed, but I had watched some youtube videos of people doing the plugs on the H4. Totally different setup!
When did the Gen3 die??? I missed it, what happened?Changed the plugs on my V6 Tacoma yesterday. Really puts into perspective how much more difficult the H6 is. Tacoma took me ~45 minutes, maybe less. My record on the Subaru was about 2 hours. First time was about 3.
This, unfortunately: http://www.subaruoutback.org/forums/61-general-discussions/156866-totaled.htmlWhen did the Gen3 die??? I missed it, what happened?
