1 - 7 of 7 Posts
'02 Outback H6 VDC Sedan
Been procrastinating, haven't contacted the Man yet to check fitment of lift kit ADF 00-04.OB-4LK. Anyone know if it will work on a sedan? I've got no good reason to do it other than being redneck.
pics of rust?
such should work fine, 4 " is a big lift though
2" is about as much as many here would recommend as anything past that makes for FAST part wear. (like axles).
My attempt at rust pictures, I'm a technology rock.
it will work same as on wagon. still 4'' lift is just 2'' lift on struts and rest 2'' is made on body. end result same ground clearance as with 2'' lift. unless you ut there stronger springs then driving would be harsher too and worse on offroad.
Good to know it will fit. Trying the rust pic's again. I'll get to 10 post yet!
now you got 10 posts, and you can link away (just not from photo-suck-it)
rust looks surprisingly great for ohio. ...I mean like nothing.
(and I thought there would be fist sized holes over the rear wheels and in the dog leg of the rear doors)
I'm hoping to get some patch work done on the rust this spring. Will be a priority over a lift kit. Got a 2000 4 cylinder OB sedan in the barnyard (ugly maroon) that I drove with bad head gasket till it died. It has the
fist sized rust holes
1 - 7 of 7 Posts
