1 - 10 of 10 Posts
2016 3.6R Limited
Was curious to hear if anyone on here has installed Raptor headers on their 3.6R. I have a 2016, and have been considering it, but wanted to hear if anyone has had experience with them.
Thanks!
Brucey
'17 3.6
They won't fit the Gen 5 even though on the site they say they do. You either have to extend them about an inch to clear the frame or use a 1" spacer between the header and the block. Doing that requires changing the lugs in the block for longer versions.
Master Caster
The 2015 on up have a bit of a fitment issue. They actually need to be extended to work and clear properly. Extended from the head flange side...kind of a pita. See @Brucey 's .... thread where he sold his.
Master Caster
What he said....
Brucey
'17 3.6
Further information from now defunct skunk works project:
I tried dry fitting them. They specifically hit the front sway bar and a bolt on the sub frame. I suppose if you removed those bolts and the front sway bar (or spaced the sway bar up) they could possibly fit without issue.
I didn't care that much.
2016 3.6R Limited
Interesting. I thought I had read something on one of his FB posts that they came out with one that will fit the 16'. Good to know though. Appreciate the info, guys!
Brucey
'17 3.6
I can show you my discussions with raptor but basically the answer is it will work but require modification.
Someone did it with a legacy 3.6 then promptly sold it.
2016 3.6R Limited
Discussion Starter #8
Got it. Really good to know! Thanks for the info. Are you running any sort of catback?
2014 Outback 3.6R Limited
4 questions:
Will Raptor Headers fit a 2014 3.6?
What is the name of Raptors web site? (A direct result does not come up when I search Raptor Headers).
What other exhaust system parts are necessary to use them? (And whats the preferred brand?).
4 questions:
part of the supercharger kit. @traildogck has installed and or worked on a friend's 2010-14 outback 3.6 with raptor stuff on it like headers.
(maybe the supercharger is in hand now).
Subaru Liberty/Legacy 5Gen 3.6R Supercharger Kit | Raptor Superchargers
1 - 10 of 10 Posts
