I have a 2015 Outback with electric lift hatchback. Last summer I had the lift mechanism replaced because it was clicking - it was replaced under warranty. Today I heard a humming noise when it was in the garage - it seemed to come from the drivers side rear panel - where i assume the lift mechanism is located. I raised and lowered the tailgate, thinking that is was not closed properly. This also happened about a month ago and all I did was raise and lower the tailgate and noise stopped immediately. Not this time. However, I went out the garage again - about 20 minutes later and the noise stopped. My concern is having the battery run down. Has anyone else had this problem? Thanks.
2014 OBW Premium (Ice Silver Metalic)
If I'm not mistaken it's a normal function of an emissions self-test. I have a `14 Outback and mine does it, too. Described in the owner's manual.
Indeed.
Page 8 (at the front of the OM)
Noise from under the vehicle
NOTE
You may hear a noise from under the
vehicle approximately 5 to 10 hours
after the engine is turned off. However,
this does not indicate a malfunction.
This noise is caused by the operation
of the fuel evaporation leakage checking
system and the operation is normal.
The noise will stop after approximately
15 minutes.
