1 - 12 of 12 Posts
2011 Outback Limited 2.5
I sleep on a twin sized air mattress back there whenever I go camping, so I think so
Brucey
'17 3.6
Twin sized mattress and box springs are 39" by 75" nominal.
Actual varies an inch.
The mattress can give a little.
The box spring can not.
It will fit but will be tight on a Gen 5.
Might need to push the seats forward.
Should be doable.
As for air mattress if its little too wide just release some air from it and it will bend on sides and still will be very good to sleep on.
'13 2.5 Premium
Should be doable.
My main concern is how far forward I will have to tip the driver's seat. Especially if I try both at the same time. Since the tailgate slopes in a bit the higher it goes, this might take 2 trips or a different option.
2010 2.5 CVT Limited
Last time I hauled a twin sized mattress and box, they were just a bit too long to close the hatch. It was close, just a couple of inches. I ended up tying down the rear hatch with a carabiner through the latch mechanism and paracord to the latch loop. I was only going about 30 minutes away so it was fine.
Keep the HVAC on outside air or leave windows open to prevent exhaust gas buildup.
Brucey
'17 3.6
You could throw it on the roof just as easy.
Use some slipknots with 40lb + rope and it will hold.
Or preferably some ratchet straps.
2014 Outback, 2.5 Premium / CVT
I saw a mattress go airborn, about 15 or 20 feet in the air, on the interstate last week. :surprise: Thankfully no one was tailgating at the time!
How many times have you seen a mattress on the side of the road and wondered why people dump them there? (Hint- they are not all dumps!)
2013 Outback Premium - 6spd manual
Twin mattress fit just fine in my 2013. Was even able to leave driver-side seat in normal position. Adding a box-spring, you may need to move both seats up. I'd put the box spring on the bottom.
Good luck!
1 - 12 of 12 Posts
