2007 forester that looks well maintained. recent head gasket replacement (felpro multi layer), but original head bolts. Other work has also been done, does not use oil, reportedly and appears to have the non CVT trans.
How concerned should I be about not having put in new head bolts?
Everything I've seen here on headgasket replacement suggests that reusing head bolts is fine, at least once. The 2005 Outback Factory Service Manual doesn't suggest replacing them either when reassembling heads (it does say to use a new gasket, obviously.
Not done it myself, although I do need to get my headgaskets done.
Technically they're re-usable. Most people replace them anyway because that's what you usually do on other cars and "might as well". I used to be a Subaru tech and have re-used head bolts plenty of times with ill-effect.
Thanks. I did just look up the Fel-Pro head gasket and it says "head bolt replacement required". That, of course, concerns me. Most of the "gasket only" offerings on RockAuto also state that, but I think they are all of the MLS type.
Fel-pro's comments about headbolts is a one-size-fits-all comment with little merit. The Subaru standard of not replacing the bolts is perfectly fine. Numerous Subaru speciality shops and the dealers don't replace the headbolts.
If I did ever install new headbolts, which I haven't, I certainly wouldn't use Fel-Pro supplied bolts.
I'd look more into which shop did the work - the more reputable and/or Subaru experienced they are the better I'd feel about it.
Did it get new timing belt and pulleys during the job?
Thanks for all the reassurance about the head bolts.
He says timing belt and water pump were replaced. I'd assume the pulleys also, having gone that far, but will check.
What do you have against the Fel-Pro bolts? Other than being so expensive?
I hear some say it is critical to surface the heads others just say checking for warp with a straight edge and feeler gauges is good enough, and maybe check the valves. For me, as long as the head surfaces look "pretty good" and there is no warp, I might just lap the valves and replace the stem seals. Never did a Subaru, but I have had shops completely hose up aluminum heads.
Related Threads
Subaru Outback Forums
1.9M posts
188.8K members
Since 2003
Welcome to the Subaru Outback Owners Forum, we have tons of information about your Subaru Outback, from a Subaru Outback Wiki to customer reviews.
