99 OTBK 5MT, 2014 OTBK 6MT
Howdy,
I have a 99 outback 2.5, EJ25D, 5 spd manual. The head gaskets went out about 2 weeks ago, pulled the motor to do the repair. I was using a 1/2 inch breaker bar about 3 feet long with a 12 pt deep well 14 mm socket to break the torque on the head bolts. I actually had one 14 mm socket break while trying to get them to break torque, I heard a snapping sound as if the the socket turned on itself, so it had jumped to the next tang inside the socket head. The camshafts are out so I have a direct access to the bolts. The tops of the bolts are a green paint, all of them
Question is should I use an impact wrench to break the torque or am I missing another avenue to get them free.
Your thoughts please.
Do not impact them: you are likely to take the threads with you.
The snapping sound is pretty normal. It's the sound of the washer and threads breaking contact with the aluminum head and threads. They will usually snap/pop a few times before letting go and get easy to turn.
Support the head of the breaker bar while cranking. You will likely have to pull against the engine/engine stand while cranking. You avoid bending the bolt this way.
Make sure you LIGHTLY oil the threads and underhead surface when reassembling. This prevents the popping/snapping and giving you a false torque and yield reading.
awesome to have roughdiamond around for info like this!
At least my experience is good for something... lol
Acquired by blood, tears, or sweat: experience is experience.
